Similar to the below, but for the alerting section, like active alert, which application, server, node triggering more alert like that.
Do we have any swql query for that?
SteveK, given the endorsement or your code by KMSigma I would really like to give this a try. You have several custom properties related to both email and responsible teams. In my environment (so far) I only have a custom property for 'system_owner', which is an email address. Is there a way I could simplify your code to use this single custom property?Thanks!Joe
Thank you for sharing this very useful SWQL.It help a lot to understand how the Alert Dashboard is created.By utilizing this SWQL, i created modern dashboard as shown below.To further enhance the dashboard for operational, 1) how to include interactive button inside the table to be similar with the OOTB (Out-Of-The-Box) "Alerts & Activity > Alerts" dashboard so that the engineer can click that button to Acknowledge and put the Annotation? 2) how to add buttons on the top on the "Active Alert" table to show the total alerts grouped by Severity. and when the button is clicked, the Active Alerts will be filtered to show only the alert with that severity to be similar with the widget in the "My Dashboard > Network > NPM Summary > Active Alerts" ?
This is a thing of beauty. You should be very proud of yourself @SteveK because I am duly impressed.
Curious about the reason for the WHERE 1=1 and WHERE 2=2 near the end, but otherwise...
WHERE 1=1
WHERE 2=2
I wanted to share what I have on my alerting table. So one of the issues I ran into, is we use custom properties pretty heavily for our alerts. Basically all of our emails are tied to a Email custom property for the object type. When trying to create a dashboard for the teams, this became a bit of a struggle since I didn't really have a good way to filter. I forget what was original code and what was lifted or modified from other queries and dashboards. I believe the active time came from one dashboard, and I want to say I used the link @KMSigma.SWI referenced for the base of the table layout.
To make something usable for our end, I ended up doing a subquery with various Cases to populate back the custom properties. This then allowed me to easily filter in my where clause for the teams, and provide a clean-ish select statement at the top. Anything in the [CP] table is the subquery which gets nasty. The subquery would need to be edited to line up with your environment. The main things I pulled over for ours is a Responsible Team property and an Email address field. Each object (Node, Volume, Datastore, Application (and component), Transaction (and step)) has a corresponding custom property for this.
When I build out the modern dashboard widget, I have:An Alert name which hyperlinks to the alertSeverityObject (Node, Volume, Virtual Machine, etc....)Triggering Entity (Name, Status, Hyperlink)Related Node (Name, Status, Hyperlink)EmailResponsible TeamTrigger TimeTime ActiveAcknowledge by
SELECT [AA].AlertObjects.AlertConfigurations.Name , '/Orion/NetPerfMon/ActiveAlertDetails.aspx?NetObject=AAT:' + ToString([AA].AlertObjectID) As AlertDetailURL --Build Out URL/URI , [AA].AlertObjects.AlertConfigurations.Severity , [AA].AlertObjects.EntityCaption , [AA].AlertObjects.EntityDetailsUrl , [CP].EntityStatus , Case [AA].AlertObjects.EntityType When 'Orion.Nodes' then '[Self]' Else [AA].AlertObjects.RelatedNodeCaption End As RelatedNodeCaption , [AA].AlertObjects.RelatedNodeDetailsUrl , [AA].AlertObjects.Node.Status as RelatedNodeStatus , ToLocal([AA].TriggeredDateTime) As TriggerTime , CASE WHEN MINUTEDIFF([AA].TriggeredDateTime,GETUTCDATE()) > 1440 THEN (TOSTRING(ROUND(MINUTEDIFF([AA].TriggeredDateTime,GETUTCDATE())/1440.0,1)) + ' Days') WHEN MINUTEDIFF([AA].TriggeredDateTime,GETUTCDATE()) > 60 THEN (TOSTRING(ROUND(MINUTEDIFF([AA].TriggeredDateTime,GETUTCDATE())/60.0,1)) + ' Hours') ELSE (TOSTRING(MINUTEDIFF([AA].TriggeredDateTime,GETUTCDATE())) + ' Minutes') END AS TimeActive , [AA].Acknowledged , [AA].AcknowledgedBy , [CP].EntityObj , [CP].Email , [CP].ResponsibleTeamFrom Orion.AlertActive [AA] Left Outer Join ( SELECT [AO].AlertObjectID , Case [AO].EntityType --Sets a clean value for alert object type When 'Orion.Nodes' then 'Node' When 'Orion.Volumes' then 'Volume' When 'Orion.APM.Component' Then 'Component' When 'Orion.APM.Application' Then 'Application' When 'Orion.VIM.Datastores' then 'Datastore' When 'Orion.VIM.VirtualMachines' then 'Virtual Machine' When 'Orion.SEUM.TransactionSteps' then 'WPM - Step' When 'Orion.SEUM.Transaction' Then 'WPM - Transaction' When 'Orion.Engines' Then 'Orion Server' Else [AO].EntityType --Entity type not accounted for End As EntityObj , Case [AO].EntityType --Retrieves status of Object When 'Orion.Nodes' then [AO].Node.Status When 'Orion.Volumes' then [V].Status When 'Orion.APM.Component' Then [C].Status When 'Orion.APM.Application' Then [App].Status When 'Orion.VIM.Datastores' then [DS].Status When 'Orion.VIM.VirtualMachines' then [VM].Status When 'Orion.SEUM.TransactionSteps' then [TS].Status When 'Orion.SEUM.Transaction' Then [T].Status When 'Orion.Engines' Then [SW].Status Else 0 --Entity type not accounted for End As EntityStatus , Case [AO].EntityType When 'Orion.Nodes' Then [AO].Node.CustomProperties.Email When 'Orion.Volumes' then [V].CustomProperties.VEmail When 'Orion.APM.Application' then [App].CustomProperties.AEmail When 'Orion.APM.APplication' then [C].Application.CustomProperties.AEmail When 'Orion.VIM.VirtualMachines' then [AO].Node.CustomProperties.Email When 'Orion.VIM.Datastores' then [DS].CustomProperties.DSEmail When 'Orion.SEUM.Transactions' then [T].CustomProperties.TEmail When 'Orion.SEUM.TransactionSteps' then [TS].Transaction.CustomProperties.TEmail When 'Orion.Engines' then [SW].CustomProperties.Email Else Concat('N/A - ',[AO].EntityType) End As Email , Case [AO].EntityType When 'Orion.Nodes' Then [AO].Node.CustomProperties.ResponsibleTeam When 'Orion.Volumes' then [V].CustomProperties.VResponsibleTeam When 'Orion.APM.Application' then [App].CustomProperties.AResponsibleTeam When 'Orion.APM.Component' then [C].Application.CustomProperties.AResponsibleTeam When 'Orion.VIM.VirtualMachines' then [AO].Node.CustomProperties.ResponsibleTeam When 'Orion.VIM.Datastores' then [DS].CustomProperties.DSResponsibleTeam When 'Orion.SEUM.Transactions' then [T].CustomProperties.TResponsibleTeam When 'Orion.SEUM.TransactionSteps' then [TS].Transaction.CustomProperties.TResponsibleTeam When 'Orion.Engines' then [SW].CustomProperties.ResponsibleTeam Else Concat('N/A - ',[AO].EntityType) End As ResponsibleTeam From Orion.AlertObjects [AO] Left Outer Join Orion.Volumes [V] on [AO].EntityDetailsURL = [V].DetailsURL Left Outer Join Orion.APM.Application [App] on [AO].EntityDetailsUrl = [App].DetailsUrl Left Outer Join Orion.APM.Component [C] on [AO].EntityDetailsUrl = [C].DetailsUrl Left Outer Join Orion.VIM.VirtualMachines [VM] on [AO].EntityDetailsUrl = [VM].DetailsUrl Left Outer Join Orion.VIM.DataStores [DS] on [AO].EntityDetailsUrl = [DS].DetailsUrl Left Outer Join Orion.SEUM.Transactions [T] on [AO].EntityDetailsUrl = [T].DetailsUrl Left Outer Join Orion.SEUM.TransactionSteps [TS] on [AO].EntityDetailsUrl = [TS].DetailsUrl Left OUter Join Orion.Nodes [SW] on [AO].EntityCaption = [SW].Caption ) as [CP] on [AA].AlertObjectID = [CP].AlertObjectIDWhere 1=1-- And [AA].Acknowledged is NULL-- And [AA].Acknowledged = TRUE-- And [CP].Email like '%EMAILHERE%' And 2=2
Probably, cant remember where I got it from and revised several bits. There's a couple columns there no-one needs but hey I had it to handEveryone else, if 2 people recommend a page, and one of them is @KMSigma.SWI use his one first
Is this tweak on the SolarWinds Active Alert Dashboard , @adam.beedell ?
SELECT aa.AlertActiveID,CASE WHEN ao.AlertConfigurations.Severity = 2 then 'Critical' WHEN ao.AlertConfigurations.Severity = 3 then 'Serious' WHEN ao.AlertConfigurations.Severity = 1 then 'Warning' WHEN ao.AlertConfigurations.Severity = 0 then 'Informational' WHEN ao.AlertConfigurations.Severity = 4 then 'Notice' ELSE concat(ao.AlertConfigurations.Severity, '') END AS [Severity], CONCAT('' , ao.AlertConfigurations.DisplayName, '') AS Alert , a.triggertimestamp, a.TriggerCount AS [Recent Alert Count], CASE WHEN Minutediff(a.triggertimestamp,GETUTCDATE()) BETWEEN 0 AND 119 THEN concat('',Minutediff(a.triggertimestamp,GETUTCDATE()), ' Minutes Ago') WHEN HOURDIFF(a.TriggerTimeStamp,GETUTCDATE()) BETWEEN 2 AND 48 THEN concat('',HOURDIFF(a.triggertimestamp,GETUTCDATE()), ' Hours Ago') ELSE concat('',DAYDIFF(a.triggertimestamp,GETUTCDATE()), ' Days Ago') -- ELSE concat('',a.TriggerTimeStamp,'') END AS [Trigger Time] , concat('',ao.AlertNote,'') as [Ticket], concat('',ao.AlertActive.AcknowledgedBy,'') as [Acknoledged By], concat('',ao.AlertActive.AcknowledgedDateTime,'') as [Acknoledged Time], CASE WHEN ao.RelatedNodeCaption IS NULL then CONCAT('',ao.EntityCaption, '') WHEN ao.EntityCaption = ao.RelatedNodeCaption then CONCAT('',ao.EntityCaption, '') ELSE CONCAT('',ao.EntityCaption, ' on ','', ao.RelatedNodeCaption,'') END AS [On]FROM Orion.AlertActive aaLEFT JOIN Orion.AlertStatus a on aa.AlertObjectID = a.AlertObjectIDLEFT JOIN Orion.AlertObjects ao on a.AlertObjectID = ao.AlertObjectID
@KMSigma.SWI Do we have any
