After the April 2024 OS/.NET updates were applied we lost all Report images, they are now displayed with the broken image 'image'.
Any suggestions on how to fix?
Settings -> Web console settings -> Logos on there I think, references the filepath so you can probably pull a backup from that location
Thats the site logo, different topic.
Reports -> Create report -> Browse for Logo?
Not working, thats the underlying issue. Its not taking anything you put in.
I assume a config wizard is needed but hoping for a less intrusive fix.
Definitely open a case with Support about this. They might know of a specific fix for this issue as opposed to something as intrusive.
Well, today all is well. Magically, all images are appearing.
