I would like to submit a feature request for Remote Ping. Currently, many users need to perform Remote Ping on network devices. Remote Ping function is expected to be added to the NPM module..
yes ,you are right. now it's sure , many Customer need this request.
You need to submit FR's in the right location. It would also work better if you expand on your requirements and reasons for wanting this, and if feasible any screenshots that could help your argument.For NPM that would be here: https://thwack.solarwinds.com/product-forums/network-performance-monitor-npm/i/feature-requests
The Feature Request process is outlined in How to create a Feature Request - THWACK Documentation - THWACK Command Center - THWACK (solarwinds.com)
