Hi, has anyone had the following after upgrading to 2022.4 on APE & AWS?
MPE is OK but get the same CW error on 5 x APE and AWS.
Have tested port connectivity on from APE to MPE looks OK
Thanks @bshopp this was resolved by Tech Support doing a full repair on the MPE, then running config wizard on all the APE/AWS
Yes - we have had a case open with support since Friday for a system down because of this. As they were unable to fix it, we are in the process of restoring our server back to the prior version.If you haven't already then I strongly suggest you open a call with support.
Thanks @stuartd
Have a case open since Saturday, no feedback as yet.
I was able to manually start services on the APEs and AWS which seemed to work
Error still persists
Yes, same situation as us and we rolled that environment back to 2022.3The other (large) environment that we have on 2022.4 has 2 of our APEs with the above message, but the rest are fine. Like you say - we started the services and they seemed to be working.
Strange one, we even had the team remove McAfee and turn off firewall without success.
Logging into RabbitMQ Console shows no connections.
Not sure if reinstalling RabbitMQ might resolve, will wait for official comms.
Hopefully no downtime for that...
Do let us know how you get on....
