Can you please guide us where we can get the attached table for customer usage that represent the below graph.
I believe the data for this graph will be in Orion.NPM.InterfaceTraffic entity, accessible via Solarwinds API. You can check with SWQL Studio too.
Google Solarwinds Orion SDK and you will find information about the API. The stats you are looking for are available to query from an external tool if you need to.
Are there any APIs by which we can show this graph on the external system ? If yes then can you please send me the URL ?
This is a screenshot from Perfstack. You can learn more here support.solarwinds.com/.../SolarWinds-Performance-Analysis-PerfStack
