Is there an update or at least an ETA on when these new SAM templates will be released?
ive upgraded to Orion 2020.2.6 HF4 and doesn't look like any new templates are out... So following up with support on this bug.
Hi @acurrent may I ask on the update on this thread, did the solarwinds released the new SAM template for azure? We have the same version of SAM (SAM HF4: 2020.2.6) deployed in our production environment, many thanks in advance.
I hope to see an update on this as well. Same issues here.
New Azure templates were released on March 24th, 2022. Available in the Content Exchange.
Application Monitor Templates - Server & Application Monitor - THWACK - SolarWinds Community
