I have a few reports that report CPU usage in %, but I have a need to report it in raw MHz or GHz. I see some CPU Usage stats that seem to measure this way, but they are all empty. Is there a way to do this in Solarwinds?
Depends on the products, but generally speaking, it is possible. Some systems do not report Hertz, so we are locked by that, but..... sometimes you can also get the "processor" speed and then multiply that with the percentage and go from there.
What products are you using? That'll help inform a report.
Pretty standard stuff. Windows servers and vmware. Some of the VMs are using agents and some are using WMI.
Sorry - I was unclear - which SolarWinds Orion products? (NPM, SAM, VMAN, etc.)
Oh sorry. The only one I really care about for this is SAM. We don't have VMAN. We have other modules but I only really want this particular monitoring for our servers.
Good enough. I'll try and stick to data sources I know are populated by SAM. Might be a bit while I dig around, but I know the data is in there somewhere.
Thank you for the help. Im going to keep digging too.
