hello everyone,
i'm new and i'm learning how to create subnets in IPAM using powershell. can someone help me ?
thank you
thank you, it's working i had to run with another account.
Did you look at the IPAM documentation on the GitHub Wiki?
when i try to run this command Invoke-SwisVerb $swis IPAM.SubnetManagement CreateSubnet @("10.10.1.0","21")
i got an access denied.
# Source: https://github.com/solarwinds/OrionSDK/wiki/IPAM-2019.4-and-higher-versions-API#create-new-subnet# Full syntax would be this:Invoke-SwisVerb -SwisConnection $SwisConnection -EntityName "IPAM.SubnetManagement" -Verb "CreateSubnet" -Arguments @("10.10.1.0", "21")# Where# $SwisConnection is the variable containing your SWIS Connection information.# "10.10.1.0" is the base address of the subnet# "21" is CIDR notation for the subnet mask.
If you aren't familiar with the SWIS connection information, I'd recommend watching SolarWinds Lab 86: An Introduction to PowerShell and the Orion API.
If you have a good connection to the SolarWinds Information Service, but still are getting the error, then your particular user doesn't have sufficient rights to build a new subnet in IPAM.
my connection to solarwinds is good, and i'am an admin. i don't understand why it doesn't work.
Import-Module SwisPowerShellAdd-PSSnapin SwisSnapin$swisCred= Get-Credential -Message "enter"$swis = Connect-Swis -Host "xx.xx.xx.xx" -Credential $SwisCred Invoke-SwisVerb -SwisConnection $swis -EntityName "IPAM.SubnetManagement" -Verb "CreateSubnet" -Arguments @("10.10.1.0", "21")
What version of IPAM are you running?
You should be only using the SwisPowerShell module and not the PSSnapin (because it's been deprecated).
I don't have IPAM in my home lab, but if I had to guess, my gut says that you might already have a subnet like that (or an overlapping one) in your environment.
hello,
thanks for your response.
the version is 2020.2.4
