The query below works and is extremely useful...
SELECT DisplayName
, IPAddress
, 0 + ToString(ARRAYVALUEAT(SPLITSTRINGTOARRAY(REPLACE(IPAddress,'.','|§|§|')),0)) AS O1
, 0 + ToString(ARRAYVALUEAT(SPLITSTRINGTOARRAY(REPLACE(IPAddress,'.','|§|§|')),1)) AS O2
, 0 + ToString(ARRAYVALUEAT(SPLITSTRINGTOARRAY(REPLACE(IPAddress,'.','|§|§|')),2)) AS O3
, 0 + ToString(ARRAYVALUEAT(SPLITSTRINGTOARRAY(REPLACE(IPAddress,'.','|§|§|')),3)) AS O4
FROM Orion.Nodes
ORDER BY O1,O2,O3,O4
... and is referenced a couple times on the thwack site in posts that are either closed or are in the feature request section (old)... the last mention of it I could find was from 2018.
Can someone show me where the splitstringtoarray function is documented and the role the section symbol (§) plays in it OR is there a better equivalent to the above query I should be using in SWQL?
...or did the section symbol get used simply because it's not often used and it plays no special role in the function?
