We have a tech group comprised of L1 and L2 techs. Why can't both levels see all tickets for that group in the group tickets tab?
Have you cleared the Query and Filter for the the Group Tickets view?
Do you have other tech permissions such as :
Limit to Assigned Tech GroupsLimit by Location GroupLimit by Department Group
These particular techs are admins so no permission limitation as far as I know. How do I clear the Query and filter, or can you point to the documentation around that? I'm still searching
Any other thoughts around this?
For filter click clear and remove the Query if you have one assigned:
Check you haven't places those admins in any Tech Permissions, as this can be screw-up your admins...
Are the admins in both Levels? They will need to be if they want to see those tickets in the Group Tickets view, else they will need to search for them or define a query to find them.
Well, I don't want the level 2 techs to be in the ticket assignment rotation. So they are not in level 1. But I hoped we could have level 1 tickets show in the group tickets tab by default for level 2 techs. Just so they can check for any complicated issues. Sounds like that can only be done through defined query?
A Query is your option then.
Got it. Thanks
