quote:Originally posted by pwinterhalderUnless I'm mis-understanding, why can't you untick the ports from within the alerts window?Phil.
Is there any update on this? It would seem rather simple to add another checkbox allowing just the collection of stats on an interface. This would be extremely helpful.
John Koebel
I agree, this would be a great addition...
-Steve
Yep - that would rock.
Considering Orion is licensed per element, or per-interface in this instance, you'd think it would be in their best interest to satisfy this feature request.
Agree, i would love to see this feature in the next release
I agree with all of you. I asked fro this back in release 7.0. A simple check box to NOT monitor up/down status would be the best. Our scenario is such that with our 700 some servers, our server switches need to be monitored for stats but not for status, as mentioned in one of the other messages for end-users.
A check box tothe RIGHT of the interface for STATUS monitoring would be a good design, with a SELECT ALL for STATUS box in the right column. If one were to select ALL FOR NON-STATUS monitoring and then choose the ones that should be monitored manually, the issue would be fixed. Just my 2 cents worth.
Strongly agreed -- Statistics collection only without status monitoring would really be very helpful, to prevent pollution of my network maps and alerts.
If I understand correctly, this would also solve my issue with force monitoring interfaces not in an up/up status.
Having to come to a seemingly quasi-supported forum to ask for future requests seems a bit unprofessional to me. I am about to start rocking the boat, not here obvioulsy. See my post in this forum "Forced Polling on Non Up/Up Interfaces" that has yet to be replied to by a Solarwinds employee.
I also don't care for the blinking red icons, and if we can kill two birds with one stone then this seems like a great request, and I will press the issue.
Any response on this yet?
I'm looking at the original problem, and you want to alert on a down state for some interfaces but not others. That's very possible today using custom properties. Label some interfaces "Critical" and other interfaces "NotSoMuch". Then add "custom property=critical" as another condition on your alerts.
Although you will still see that status as down on the web, you can use filtering in your resources to do what you want. For instances, you can add two instances of a resource and filter one to show Critical interfaces only.
Does that address the original issue?
We still the have the "wrong" icon on the nodes in the Tree Views and so on. (Blinking red dot's)
Do you have a suggestion for filtering on the "Nodes with problems" resource, so that Nodes which only has down interfaces marked as "NotSoMuch" down doesn't list here? but gets listed if interfaces marked "Critical" goes down.
/heZ
( PS Would also make a reminder of the actual fact that this in many cases reduces the amount of interfaces customers enable monitoring on, due to the fact that you loose the overview of the Critical aspect, we held of our upgrades over a long period because of this.)
I think you'll need need to write a SQL statement. I'm not a SQL guy. Can anyone in the community offer any advice?
This isn't a SQL issue. Denny.
We can always opt not to send an email notification based on advanced alert criteria (This is very easy to do) - but rather a node appearing as "down" on the maps. As an example here, I'll have an icon for my major cities, with each building within the city as child map objects.
If any "noncritical" interface was down, the entire city appears yellow, signifigantly increasing the false negative alerts. At this point We are ignoring the colour of monitored nodes in Orion.
All we want is a way to ignore the up/down status of a node, perhaps always return them as 'statistical' only. This has forced some of us to set up completely new Cacti instances just to monitor server port error & bandwidth statistics as to not corrupt the rest of solarwinds.
We're adding a feature in Orion to allow you to set some interfaces to show as "unplugged" instead of "down". Then a node is plugged into a switch, you would see it as up, but when the PC or laptop is removed from the network, the status will show as unplugged, not as down. This solution should allow you to collect statistics and alert on bandwidth hogs, and you'll be able to alert when it's unplugged (if you'd like), but these interfaces won't show up as down in alerts or in lists of down interfaces.
Would that solve the problem?
ETA on this feature? Very critical as we're now using Orion as a NOC monitor ... very embarassing to have clients and guests in our NOC when multiple devices are showing down on our large screen monitors.
this will make me very happy when i see this... had been noticing that there are states that can not be accessed on interfaces and nodes and have really just been waiting for an anouncement that we could start using them.
ETA is the next major release. While that's probably not a fully satisfactory answer, it has the redeeming quality of being true.
Denny,
Am I rigth in assuming that this would only be in release 10.0 or X whichever you decide to call it. I know you guys are very busy, but just reading this forum and not taking into consideration the number of times this had been requested over the years it seems that it has taken quite a while to be added into the development stream.
I would like to see Solarwinds as the defacto product that is used for NMS. People think NMS they think Solarwinds, and hopefully not a little of solarwinds, a little of LMS, a little of Nagios/Cacti.
Miron
Trust me, I'm aware that this feature has been requested for a long time. We're definitely in a position to make this change now, in a way we haven't been before, for technical reasons. It's something we're actively working on, which is the most I can say about when it'll ship because I don't have firm dates yet.
