Does anybody know if there is a way to backup the UCS archive on the BIGIP's, I think the current template in CatTools only backs up the config file. You really need the UCS archive to be able to restore devices properly.
Many thanks
Mark
I asked this a couple of years ago and the only answer I could come up with was to make a copy of the config upload but use the "alternate command" option to do a "bigpipe base list" as well, This way you get two configs - one for the interfaces and so on and the normal one for the pools, vips etc.
It isn't as useful as a UCS backup and doesn't include the certificates but it does at least pick up all changes and allow you to spot when another manual UCS backup is a good idea.
David
thanks for the tip, I will give that a try and see how it works out.
The ideal situation would be to be able to do a UCS but looks like it's not possible. Just wanted to check if anybody else had any luck.
Thank you
How would you manually backup the UCS archive on the BIG IP from the command line?
Wardini
Hi Wardini
from the command line you run the command:
bigpipe config save %filename% (generally the hostname of the device)
It then creates a *.ucs file in /var/local/ucs which then needs to be scp'd off the device.
The ucs file contains all the config, the SSL certificates, Licenses etc. It can be used to completely restore a box.
Do you think this is every something that could be supported? I think running the command to create the backup should be OK but it's getting the file off the device via SCP to the Kiwi configs folder?
Hi Markj - we have this in our feature tracking system. Thanks for your input!
--C
Hi - this would be a fantastic feature to have for our BigIP's.!
I see a lot of feature requests from users. How many are in your tracking system and what percentage is actually being actively worked?
Hi Jon0966:
We have lots and lots of feature requests in our tracking system and with each release we a substantial amount of bug fixes, and we do features according to popularity. That is, if we have a request that is rather obscure, it probably won't get done. In the same way, if we have a CatTools request that is really functionality in the realm of NCM, it won't get done either. I hope that helps.
Sounds like I need to get all the kids registered, my mammy, Uncle Bob and Billy, my neighbors, and request features I am interested in.....
Jon - I can do better than that. I'll send you a message and set up some time to talk to you otp. I'd love to hear your ideas for CatTools.
All,
You may want to check out the following online help page:
http://www.kiwisyslog.com/help/cattools/dev_specificinfo_backupviascpsftp.htm
It may be possible to backup the F5 BigIP UCS archive with CatTools using the Device.CLI.Send commands activity and by downloading the SolarWinds SFTP/SCP Server.
From what I could tell from the command list and responses from the F5 BigIP, there wasn't any need for me to modify the device script. It looks like the commands should be handled correctly by the existing script in v3.6.0. Unfortunately I was unable to verify this (as we do not have a f5 BigIP ion our lab), so it would be good if some of you guys can test this and post back to the forum your findings.
In CatTools v3.6.0 the device variations feature http://www.kiwisyslog.com/help/cattools/dev_devicevariations.htm has also been enabled for the f5 BigIP to allow you to further extend the current 'Device.Backup.Running Config' activity with the "bigpipe base list" command as per the posting by David Rickard (many thanks David for helping to test this for me).
To set this up, do the following:
Now when you run the activity, CatTools will issue both commands and capture the output to a single text file to compare.
Note: the generated text file is not reloadable back to the device as command section headers get inserted by CatTools in order to highlight when one command output ends and the next one starts. In general, you would use this activity to receive notification of a config change, then use the Device.CLI.Send command .UCS backup to take a full system backup.
Hope this helps!
Kind regards,
Steve
We don't have CatTools. We have NCM and 4 x F5 BigIP 6900 Load Balancer. I have to backup UCS files as well. Is there any difference between CatTools and NCM?
Hi Ctopaloglu: CatTools and NCM are really different from start to finish. Are you having any particular problems with the backup and NCM? If so, please post to the NCM forum and/or open a support ticket. Or you can pm me and I'll work with you to get a solution.
--Christine
As there is no command on the F5 to view all configurations and make a complete backup, one of our clients used and provided me the following workaround:
"The cattools command is now: run cli script kiwibackup
On the F5 there are two scripts-- one TMSH script to run two commands, the first is to save a single file configuration. The second is to run a bash shell script.
The bash shell script:
1. cat the single file configuration
2. delete the files that were created
The TMSH script:
cli script /Common/kiwibackup {
proc script::run {} {
tmsh::save sys config file /var/local/scf/backupconfig.scf
tmsh::run /util bash listbackup.sh
the bash script listbackup.sh :
cat /var/local/scf/backupconfig.scf
rm /var/local/scf/backupconfig.*
(there are two files created when the run config file is done, therefore the wildcard on the 'rm')"
Hopefully this helps someone until we add support to backup the UCS Archive.
Please note that this is provided as-is and is to be used at your own risk.
Sincerely,
Chris Foley • SolarWinds • Technical Support
Office Hours: Mon-Fri 8AM-5PM EST 866.530.8040
______________________________________________
explore our IT management solutions for:
networks|applications|storage|virtualization|log & event
For those wanting to leverage NCM. Unfortunately, NCM cannot download a text based from an F5 device because this is a Binary file. NCM will not be able to process it. There has been a work around that runs a script to backup the file, but it isn't stored in the NCM database. Typically this script can transfer the file via TFTP to the NCM TFTP root directory, but it will not be stored in the NCM database.
To reference some F5 commands for scripting purposes:
https://support.f5.com/kb/en-us/solutions/public/4000/400/sol4423.html
