Has anyone combined a ticket field with a node name and status field so that a down staus node can have OPS input a ticket number and have that reflected in network summary for all to see?
Such as the figment below ......
-Ron
Wow. What an awesome idea. I've love to know if it is possible.
Well... Kinda...
Vic
I believe that's close to what I'm looking for. Does the resource on the home page correlate with a down node or is it all together a seperate information field?
Ron
I've done something similar - I added a Comments field which can be updated from the Node Details page.These comments get displayed in the Nodes Down property at the top of the Home page.
Here is the code to add this field to the Down Nodes resource here:
C:\Inetpub\SolarWinds\NetPerfMon\Resources\1-1-SummaryReports\DownNodes.resource:
%><table border="0" cellPadding="2" cellSpacing="0" width="100%"> <tr> <td class="ReportHeader" vAlign="center" width="20">Node</td> <td class="ReportHeader" vAlign="center"> </td> <td class="ReportHeader" vAlign="center">Comments</td> <td class="ReportHeader" vAlign="center"> </td> </tr><% Do While Not SQLResource.EOF %><tr> <td class="Property" vAlign="center" width="20"><%=SQLResource.GetProperty("StatusLED;SmallIcon")%> </td> <td class="Property"><a <%=SQLResource.GetProperty("NodeParamString")%> href="")%>"><%=SQLResource.GetProperty("Caption")%></a>">thwack.solarwinds.com/.../View.asp </td> <td class="Property"><a href="")%>"><%=SQLResource.GetProperty("Comments")%></a>">thwack.solarwinds.com/.../View.asp </td></tr><% This is what it looks like:
Bingo Guru! Much thanks to you and Vic!
Wow - now that's a detailed writeup - nice work Vic!
I would be interested in the code you used to add comments to interfaces as well.Could you post that as well?
-=Thanks=-
I would be interested in the code you used to add comments to interfaces as well.Could you post that as well?NG... Sure thing, I'll do my best to put it together within the next few days.
I put a little something together explaining how to edit custom properties for interfaces via the web and placed it here, in the Content Sharing Zone.I tried to explain it well enough so that anyone with basic knowledge of Orion administration can understand and utilize the information, while also not making it too detailed and convoluted. Now, let's see if I succeeded... Keep in mind that through much trial and error, I simply stumbled across how to make this work. Ya see, I ain't dat smrt.
Thanks Vic,I had a brief look at it. I like your logic, this will come in handy for other things as well.If I can figure out how to list the Interface custom property in the Web admin GUI, I'll post it in the CSZ.
Torrie,
Maybe that the Admin account is the only account with the Allow View Customization box checked?
Torrie, Maybe that the Admin account is the only account with the Allow View Customization box checked?
Guys thanks for you help. It was the EditCustomProperty.Update.asp. I didn't modify that file because all of my users should be able to edit. It works on both versions 8.1 as well as 7.5.
YAY!!! Yeah, if you want all your users to be able to edit this info, then you don't need the hack, but you would have to give them the view customization priv, and that may not be a good thing.
I am having the same problem, once I allow edit customization everything works with no issues. This is not something I want to leave this way.
Has anyone else had this problem? or figured out how to get it to work?
YAY!!! Yeah, if you want all your users to be able to edit this info, then you don't need the hack, but you would have to give them the view customization priv, and that may not be a good thing. I am having the same problem, once I allow edit customization everything works with no issues. This is not something I want to leave this way. Has anyone else had this problem? or figured out how to get it to work?
Did you implement the change to the EditCustomProperty.Update.ASP as outlined in the README file that I attached? This only allows people who are allowed to clear events to have the ability to update the text in the custom property, but they can't make other changes (with the exception of the ability to clear events).
