We have lots of device made by HuaWei Company in China.
And we get their private MIB, and there are all *.mib files.
and could I customize there .mib? how?
Thanks.
You will need to have SolarWinds compile the MIBs to be placed into our MIB database.
Please submit a ticket here and attach the MIBs with the auto-reply email from Support-
thanks
I have done it.
is this for v8 and above or does this work on v7 also?
V7 does not have the custom mib poller.
Mark,
Must I send all the mib files to solarwinds to be compiled ??
If they are not currently in our MIB repository then you will need to have them compiled by Solarwinds-
Thanks for your reply.
And what's the type of the mib in your MIB repository?
And could the router provider (Huawei Company) compile the mibs themselves?
We compile them to a DB of OIDs, the vendor cannot compile the MIBs-
At this time you will have to keep sending us the MIBs -
http://www.solarwinds.net/NetPerfMon/SolarWinds/OrionAdministratorGuide.1.179.htm
And you mean if we get the OIDs, then wen can use these OIDs directly, yeah?
So according to the Admin Guide:
Creating Custom MIB PollersWith custom MIB polling, Orion Network Performance Monitor can not only poll any MIB that is currently in the SolarWinds MIB Database, but Orion can also poll any other OID that you may need to monitor. This capability allows you to monitor virtually any statistic that your network devices can record. The following procedure uses the Custom MIB Poller Wizard to create a custom MIB poller.
Where can I find a list of supported MIBs in the SW MIB DB?I'm looking for MIB support for Cisco Call Manager blades in a 6500 Chassis (I have not yet upgraded to V8.1 - soon).
