How do I setup my ucs so I can poll for ucs with solarwinds?
Have you seen this Tech Ref?
http://www.solarwinds.com/documentation/Orion/docs/SettingUpCiscoUCS.pdf
I am having the same problem. I went through the cisco documentation, but my NPM is not seeing the services. something isn't right.
Anyone have info on the configurations for SNMP on the CUCM linux boxes? I'm running 8.6 CUCM and 8.6 CUP. I have enabled SNMP service.
I was able to add my virtual ip as the main node and fabricate A both using snmp and poll for UCS. However on my fabrik B controller I'm not able to poll for ucs? the test fails. It works for snmp and I did a copy and paste with the same username and password as fabric A. Is there something I need to do to get it to work on fabrik B?
I have same "issue". Any fix found?
Hi guys,
can you somehow summarize what problem do you experience here? Is it about adding the UCS into orion or setting up the UCS to be able polled by orion?
I will try to help you then.
Pavel
Thank you for the link to the guide. It's a great help
Hi
Thanks for reply. My issues is:
I can add virtual IP (treated as a node) in SW using Ping & UCS polling, SNMP not working
I can add primary Fabric Interconnects A in SW using SNMP & UCS polling.
I can add secondary Fabric Interconnects B in SW using SNMP only, UCS polling not working.
Is this just natural or issues with SW?
I also assign the following views in Node Details view of the 3 nodes
The results are: From Virtual-IP node & Primary Interconnects A
I also created a customised view page - UCS Chassis Details, which shows Fan & PSU information
Any idea, why Fan & PSU information is not shown in Node Details page? and no result for Blades?
I am polling both by VIP, and physical addresses the FI and still do not see the FI power supplies - I just snmpwalked it with support and the oid's on the 6200 series looks different from what Solarwinds developed the resource against for 6100 series. Unless I am mistaken this means the information is just being ignored.
PSU or Fan is shown on UCS Chasses details page only and it is polled from the UCS.
Cheers,
