I have two NPM pollers, do I install IP SLA on both systems? If so, primary or secondary first?
Hi rmmagow -
Great question.
You will need to install IPSLA Manager on both pollers. You'll want to install it on the secondary system first, so it will know how to process IPSLA Manager jobs that the primary system will send to it.
OK, so now I'm confused.
I have a support case currently open where I am having issues using IPSLA Manager against nodes defined on secondary systems. The advice I received is that an install of IPSLA manager is not required on the secondary pollers - and it's being treated as a bug.
Is this advice not correct? Is there a licence implication with installation on secondary pollers?
I can't find reference to this type of configuration in the admin guide - maybe I just missed it (along with the additional web server install notes).
Dave.
Hi Dave,
Sorry for the confusion. You do need to install IP SLA Manager on both primary and secondary pollers. There is no license implication for installing on the secondary poller.
Cool, thanks Craig.
That might get rid of our current open issue I suspect - will implement this suggestion tonight.
Chris, we already have IPSLA installed on the primary server and has been running operations for a year. We now have 2 additional pollers. Your instruction has me a little confused. You are suggesting to install the secondary pollers first. Does this mean we have to uninstall IPSLA on the primary poller first before we install to the secondary pollers? Please advise.
Hello Ron,
you can install IPSLA on secondary poller without uninstalling it from primary.
Thanks Jiri.
With multiple pollers, another question has come to mind. How does IPSLA distribute the load across additional pollers?
Hi Ron,
Polling of a node is executed on the main poller or any installed additional poller, depending on your choice. You can manage the assignments of nodes to polling engines in Node management page.
Thanks Tomas. I'm familiar with Manage Nodes and distributing nodes across pollers. What I'm unclear about is when I create a 2-way operation (e.g., ICMP PATH ECHO) using nodeA as the source managed by PollerA and the target is nodeB managed by PollerB does pollerA manage/poll the result of both nodeA & nodeB operations or does PollerA only manage/poll operations where it is the source and PollerB manages/polls operations where it is the source? I hope I made sense. How's this handled across multiple pollers with meshed operations?
Ah, ok, I see now. There is really a simple rule of thumb - a poller takes care of only operations which source nodes are assigned to that poller. So, nodeA is managed/polled by PollerA and nodeB is managed/polled by PollerB.
That answers my question. Thanks Tomas.
