We used to update report schemas, so that custom properties would work in reports, via the Custom Property Editor. CPE now launches the web UI to manage custom properties. How do we propagate custom properties to reports after an upgrade pronow?
gn
Did you ever get this resolved?
Have you tried to upgrade to 10.5? We fixed several missing CP issues in 10.4.2 and 10.5.
We did a fresh install of 10.5 and then created a number of custom properties, but none of the custom properties we created show up in the advanced alert manager. They DO show up in Report Writer. Previously we would just run "Update report schema" and it would resolve the issue.
I have a case open with Solarwinds, but the engineer I received didn't even believe there was such a button and I'm not making very good progress.
This seems to be a regular issue for the new version, it seems to me that they really missed something here as I have had this problem several times as well. I am actually working on fixing such an issue right now by running the config wizard as suggested by SW Support.
That was ultimately what resolved it for me.
For future reference, ask the tech to look up ticket 454357 - that should point them in the right direction.
Thanks Leon!
I wish they would allow us to look up 454357 so we can read it.
THanks!!!
Cheryl
The customer was on NPM 10.4.2 and SAM 5.5.
1) Install NPM hotfix 1 and 2
2) Run Configuration Wizard
3) Reboot the servers, but this should not be required.
The customer did all of those actions, and the custom application properties are now showing up in the alert trigger options.
Anybody knows how to do this on NPM 12.0? I am missing some custom properties from Report writer.
