Can we schedule the Orion Nw Performance Monitor to save Admin Views (example link:-10.254.101.80:8443/.../SummaryView.aspx) to the disk regularly lets say once per day.
You can send a PDF of your View periodically using report scheduler. see the following blog posts as you would utilize the same concept.
Hey Chart, get in my Report! (Part 1)
Hey Chart, get in my Report! (Part 2)
Ant
Dear Anthony,
I do not get the report instead I get the attached PDF (When I send as PDF File). No Email When I send as HTML Email.
Thanks and Regards,
Vijay Anand Thattandi Manickam,
I was able to follow the work instruction in the blog articles. Perhaps its an internet explorer security setting, something to do with UAC or even what is mentioned in this
Microsoft KB article. Are you able to browse to the URL you specified in report scheduler from an RDP session on your Orion server?
Yes I can browse to the page in Report Scheduler from an RDP session in my Orion server.
I login using the login user/password….. and then select the page…( I can see the page in the report scheduler…
But, When I receive the email…. It is as I showed you.
THere int much more I can do From my side. Are you able to log a support ticket to get your local issue checked as the process I sent you works.
Upon opening a support ticket, would you please post back here with your ticket #? Please keep us updated with your progress.
Thanks!
DH
Dear Danielle,
The Support Contract is finished…
