I'm getting this trying to manage nodes after my upgrade to 9.5. Anyone else having this issue. Happens from work station and on server also.
I have not heard that from anyone else. Have you opened a Support ticket?
I just submited a support ticket. I'm also getting the error on the server:
Database configuration failed: • Incorrect syntax near 'EXTERNAL'. You may need to set the compatibility level of the current database to a higher value to enable this feature.See help for the stored procedure sp_dbcmptlevel.
Thinking very seriously about rolling back to v9.0 sp5......
Ah, that helps a ton, see KB here
the compatability level window is grayed out. says SQL Server 2000 (80)
do you think the issues are related or 2 different issues?
Seems like they may be related, do you have a support case open?
I do...
Your request for assistance has been received. Case #99284 - "Getting Internet Explorer Error" has been created for you. A member of our customer support team will respond to your case as soon as possible.
Thanks for the help thus far..
OK, once you work with them and get this sorted out, please post back to the thread
OK took care of the compatability level settings, still getting same error when trying to manage nodes. Trying SP1 right now...keeping fingers crossed.
