How I can monitor a specific service on Windows and Linux?
Hi. You'll just need to browse for components and add what you want to a new template. This can be accomplished through the "Component Monitor Wizard" in Applications tab > SAM Settings > Component Monitor Wizard.
And for a Linux?
Same steps apply for both Windows and Linux nodes.
You can also do this directly from the Node Details view by Launching the "Service Control Manager" (Windows Only) or the Real-Time Process Explorer (Windows or Linux). Once opened, simply select the process or service you want to monitor and click "Start Monitoring".
I do not see "Real-Time Process Explorer" in my Management Node Details, nor is it available to add. Is this an extra application or module?
The "Real-Time Process Explorer" is included with Server & Application Monitor, which is a product that would integrate with your other SolarWinds products if you do not already have this one.
