quote:Originally posted by rwagner007I am in the process of sizing my network to determine which version of Orion I need and am wondering whether an element refers to a single device or a single port on a device. For example... does a 24 port switch count as 1 element or 24 elements? Please help. Thank you in advance for your kind assistance.
I have a followup question to this.
I am trying to price out Orion NPM, Netflow and APM, per the online quote I think our enviroment will need the SL2000, but there doesnt seem to be a SL2000 for APM. do the licenses have to match? Or could I get a SL2000 for NPM, then a SL100 for Netflow(only about 15 routers in our env), then a AP250 for applicaitons?
If not and they have to line up then how do i get a SL2000 for APM? (one isnt listed)
thanks
b-
Keep in mind that this thread is from 2004. That is a long long time and many versions ago. Many things have changed.
An element is a network interface, a node, or a volume. An SL2000 means you can have 2000 of each. For most people, the interfaces will be the largest number. NTA is matched to your NPM license to reflect the size of your network.
APM is *not* tied to your NPM size. It's based on the number of component monitors you need. A component is like a process, a Windows Service, a file monitor, a script, etc.
Right 2004, gotcha.
Thanks for the information gorilla.
-b
Denny, you said something here that conflicts with an understanding I have always had about SW licensing. You said that "An SL2000 means you can have 2000 of each".
I have always understood that an SL2000 allowed you to monitor 2000 of any one of the three element types and up to 1999 of the other two for a total of as many as 5998 monitored elements on an SL2000 license.
Is that not correct?
Ah, ok. But, I don't suppose that I could monitor 2100 nodes just by choosing to monitor only 1900 interfaces. A max of 2000 of any one element type?
