How do i resolve this error message?
Unhandled exception: Exception of type 'System.OutOfMemoryException' was thrown.
As of now, some operations are down and there are no graphs generated (No Data).
Please advise.
on the main orion server, i restarted the service for IPSLA Manager and then graph data can now be seen. On the nodes, I removed one of the operation configured ont he device manually and then added it back again. Then after a few minutes, all operations on the node were up. Is this an IPSLA Manager error or the IPSLA technology on the equipment?
I would go ahead and open a support ticket (reference this thwack post when you do).
-Craig
Case 153554 created
Sounds like an issue with the module engine service for IP SLA Manager. Now that you're working through Support this will get logged and we'll take a look at it.
where in the "main ORION server"? I can not find IPSLA Manager service in windows 2008 server services. I have similar issue after getting the error above. Please assist.
The Main Orion server would be the primary NPM server. Many of our customers have multiple polling engines so the 'main' would be the primary polling eng.
There is no IPSLA manager service. It's the Orion module engine service.
This is also an old thread and we have had updates to IP SLA manager since then. Make sure you are on the latest version and your hardware meets requirements.
Once that is verified and you are still getting the same error you can open a support ticket here
http://www.solarwinds.com/support/ticket/
