I'm looking for a way to summarize the total used and free disk space for either a Group or a selected list of servers. I remember this was possible in the web view many versions ago, but not sure how to do it now. Thank you for any help.
orioncrack
Version 3 thank you for the feed back. i have now added some custom links for volumes and added per node basis i actually have another idea id like to implement into this this report it should be ultimate volume report at the end
Volume Report - Fixed Disk - Available - Size - Used - overall volume capacity NEW ** THRESHOLDS **
HI jmp99
Hope this helps you if you have any questions please ask
Volume summary report - Fixed Disk - Available - Size - Used & overall volume space
Need the report to query on Custom Property CUSTOMER. How would you tweak the code to do what the OP desires? I'm trying but its not working.
I'd like the same report. Although I already get this data with a custom View for Customers.
But I'd like to see how you can report on groups with this one.
Thanks for your help
HI orioncrack,
i have added some additional features hopefully i have answered your question here
Volume Report - Fixed Disk - Available - Size - Used - overall volume capacity NEW ** THRESHOLDS ** included
Thanks, need some guidance. Its not working for me. I have a custom property at the Node level called Customer.
When I set the code its not returning anything.
How would this be integrated for your Groups based report?
Disregard, I think I got it now.
My only issue now is I want the report to group by Node, showing all volumes.
How it should group:
NODE01
-------C
-------E
-------F
NODE02
------C
Right now there is no grouping of multi disk nodes.
C
E
The attached files are not opening, could you please attach notepad file.
