Hi all,
We just purchased Solarwinds to for our log monitoring. There is new requirement to extract monthly top 10 web users through TMG 2010 logs using LEM. Just wandering if anybody using LEM for similar usage?
Hi Hanif,
I checked with the LEM connectors team and here are the fields we currently normalize for the most common events:
As you can see, "bytes" is not included.
Two things:
I'd try using the "Network Traffic Audit - Web Traffic by Source Machine" report. What this tells you is the most # of hits through the proxy server by source, but it doesn't tell you anything about duration of their surfing. If you need to know how long they were on certain sites, I don't think there's a good way to accumulate that data with LEM and the TMG logs.
Hi Nicole,
I would like to gather the amount of bandwidth used and details per authenticated users.
Current available TMG 2010 Web Proxy Log fields technet.microsoft.com/.../cc441708.aspx ARe these available to LEM when the connector configured?
In summary I like to use following 11 fields are selected for top usage reporting:
0 Client IP ClientIP c-ip
1 Client Username ClientUserName cs-username
4 Log Date logTime date
5 Log Time logTime time
7 Server Name servername s-computername
13 Bytes Received bytesrecvd cs-bytes
14 Bytes Sent bytessent sc-bytes
18 URL uri cs-uri
19 MIME Type mimetype cs-mime-type
20 Object Source objectsource s-object-source
36 URL Category UrlCategory UrlCategory
Best of regards
Hanif
I'm not sure where the body of my message went (I sent it via email), but I am looking into which fields we capture. That said, LEM won't accumulate bandwidth data in any of the reports, so we may have to address that issue separately.
Are you saying LEM wont see Bytes Received and Bytes Sent fields for particular Client Username ?
How many field from current available TMG 2010 Web Proxy Log fields http://technet.microsoft.com/en-us/library/cc441708.aspx available through LEM?
Where can I find the complete list of items gathered by LEM from connector called 'TMG 2010 W3C Web Proxy' ?
Thanks in advance for your help.
Thanks Nicole. Hope to see this supported soon.
