Hello,
Is there any way to determine:
1. When a node is scheduled to be "unmanaged".
2. If a node is "unmanaged", when it is due to be re-managed ("unmanage" schedule expires).
I'm running Network Performance Manager 9.1 SP4
Thanks!
Here's what I use for a list of unmanaged nodes:
select caption, unmanagefrom, unmanageuntil from nodes where unmanaged <> 0 order by caption
And a list of those coming unmanaged in 7 days or less:
select caption, unmanageuntil, datediff(day,getdate(),unmanageuntil) as DaysLeft from nodes where unmanaged <> 0 and (datediff(day,getdate(),unmanageuntil) < 8) order by DaysLeft
Here's the query I'm looking for:
Select *
From Nodes
Where UnManaged = 'True'
Thanks !
a custom resource which you can put in ur homepage. Shows a table of scheduled nodes to be unmanaged. Includes a custom-made icon so you know what you are looking at.
Dan Marbes,
Where I put these code in? Could you show me it more details? Many Thanks.
I took Dan's SQL code and messed with it a little bit to get a report that shows Nodes that are Unmanaged now and in the future, including listing times. I tweaked it so that it doesn't show any records where DaysLeft is less than zero, so it shouldn't show all the nodes that aren't scheduled for downtime.
rabbid, to use the code create an Advanced SQL Report and paste the SQL code into the field in the SQL tab. Should be that easy. I've done that, then added it as part of our home page view so we have a nice list of scheduled downtimes.
SELECT Caption, UnmanageFrom, UnmanageUntil, DateDiff(day,getdate(),unmanageuntil) as DaysLeft FROM Nodes WHERE (datediff(day,getdate(),unmanageuntil) < 365) AND (datediff(day,getdate(),unmanageuntil) >= 0)ORDER BY DaysLeft ASC
Is there a way to have node name as link to allow you to go straight to node and remanage if needed?
