Can someone please tell me if it is possible to add all nodes on my network to a report en masse? If so how would you perform this?
Many thanks ahead of time!
Hi Kkillens,
What report are you working on specifically ?
I am working on a detailed view/report of nodes, and interfaces. We have hundreds of nodes and obviously more interfaces and I need many things to include errors, utilization, spikes etc. Does that help?
Thank you for your reply!
K
I would recommend implementing custom properties, once complete you would only need to include one condition. The one condition would encompass the elements desired, are you familiar with custom properties ?
Unfortunately I am not familiar with custom properties. Is there a link or quick tip you could send? Greatly appreciate your help!
You can have a Look on the "All Settings"-Page and "Custom Properties" it is pretty self explanatory.
Custom properties are like Tags you can add to certain entities in Orion.
Custom Properties are the first thing I discuss with my customers. I usually end up with more than 20 CPs. I often use the API to fill those sometimes just Alerts to fill them
