The refresh i have it set to 5 mins but it constantly goes to disabled, how come?
Version 12.1.0
From what I can tell, the refresh interval is only going to last for the active session. Once you logout or close the session and re-open it will default back to disabled. I don't see anyplace where you can set the interval as a default when the session starts.
I am leaving the page open and it stays at 5 mins for a while then it goes to disabled
NOTE: This e-mail transmission, including any attachments, is intended only for the named recipient(s) and may contain information that is privileged, confidential and/or exempt from disclosure under applicable law. If you have received this transmission in error, or are not the named recipient(s), please notify your representative immediately by return e-mail and permanently delete this transmission, including any attachments.
Definitely odd. I haven't seen or experienced that behavior. For me it stays until I either close the session or log out. What browser are you using?
chrome
Chrome is a better choice and not upgrading IE is a recipe for disaster own its own. So I can understand their recommendations
I spoke with Solarwinds and we are trying the latest hotfix as soon as we can figure out how to get write access to the Virtual Appliance
Yeah I have this problem too. Using Chrome.
I'm running 12.5.1 and this is happening as well. It occurs in Edge and Chrome and IE 11. Anyone found a fix for this yet?
Yep happens to me and all my team regularly. We've tried a mix of browsers from IE, Edge, Chrome, Firefox & Vivaldi on Win 10, 8.1 & 7. We're on 12.5.1 but it has been happening for a while.
Super annoying.
For SolarWinds: This issue is occurring across all browsers and all WHD versions up to 12.5.2 (not sure about later versions) and has been going on for years. Although the workaround is to simply refresh manually, it really needs to be resolved as it is something WHD users notice all the time. Either fix it or remove it, either way would be acceptable. Thinking about it, how does this work with the timeout settings at Setup>Authentication? If you have the Refresh setting set to 1 min and the timeout set to 30 minutes, would the system ever time our if it was refreshing every 1 minute? I think the best thing to do is remove the Refresh setting choice all together and just make it a button that you click when you want to refresh your WHD screen or do away with it all together.
The column set also gets reset during a session (normally at the same time as the refresh gets reset to disabled), which I believe is the same problem.
Happens randomly on 12.5.2 for me, and all browsers we use and platforms across our 250 techs.
Additional to this issue is the ticket filter which I believe again is related to session information, where the filter is not cleared for Request Types, even when you click clear (or close the filter panel) and shows the previous filter view of tickets, and the only to resolve it is to logout and login again.
These are simply interface session bugs, which should have been fixed years ago... Listen up Solarwinds !
regards
Chris
This was happening to some of my users here on 12.6, I installed 12.6 HF1 and the problem with the refresh reset has been resolved.
Have you opened support tickets for this. Posting on thwack forum only has a 50/50 shot of someone seeing it from SW. Opening a ticket with them is probably a better idea.
Thanks steveubano that's interesting...
Can anyone else confirm that 12.6 HF1 resolves this issue?
The release notes (WHD 12.6 Hot Fix 1 Release Notes - SolarWinds Worldwide, LLC. Help and Support ) don't say that. There is a resolved issue with the dashboard widgets sometimes not loading correctly. But I don't see anything about page refresh not working.
Any Solution to this after a year.. I see the last response is Jan 2019. The page does not populate the tickets automatically.
anyone seen this issue with 12.7.2.30 yet?
Can anyone at Solarwinds confirm that this has been now fixed after all this time?
