Hi Team,
I am trying to view the historical status of nodes in a Map,created using Network Atlas. Can someone help me on this.
Prashant
Can you describe a bit more of what you are after? Are you looking to be able to click on an element and see a specific metric over time, or are you looking to be able to compare how a map looked at one point in time vs another?
I am looking to compare the map at one point in time vs another.
There's is no such thing that I'm aware of. The map just shows the status of nodes that you place on it. You can't show a map at a point in time. You have to look at nodes individually (or as a group) on their status over time.
However it does sound interesting enough, you should do a feature request for it.
This sounds like a feature request.
Here is an option you have right now--email maps periodically: https://documentation.solarwinds.com/en/Success_Center/orionplatform/Content/core-orion-maps-alerts-reports.htm
You could build groups and populate them. And then you would have historical reporting options like this:
Using PerfStack, you can see moment in time information. You can show multiple elements and a timeline:
Further info on PerfStack: https://documentation.solarwinds.com/en/success_center/orionplatform/Content/Core-Create-Performance-Analysis-Charts.htm
If I had a dog named perfstack I think I would kick it every morning on my way out the door for being ugly.
Thanks superfly99 Just created one for the same:
Do you have suggestions or feedback on what you would prefer to see vs the current implementation of Perfstack?
