I successfully migrated from Embedded FrontBase to PostgreSQL embedded. But for new Techs with LDAP enabled upon pressing login button we are getting error as follows.
Please help to resolve this.
What version did you move from --> to? Just a thought is to log in as the default admin tech and rerun the ldap sync on your domain and see if rebuilds the user sequence.
Techs that were existing in the Frontbase at the time of migration are able to login. Newly created Techs are unable to login and getting the above error mentioned.
Newly created users without LDAP account are also able to login.
Below are the version details
Any update / help on this ?
You may want to raise an official case with support. As long as the tech has a corresponding LDAP account they should be able to log in.
