I need to create a report inventory for all servers in NPM base on hardware type and model type.
For example:
HP DL320 G4
HP DL360 G6
Have you looked through the Content exchange for any reports that might be available? I have a report that has exactly what you're looking for and I'm pretty sure I found it in the Content Exchange originally. If you can't find it, let me know and I'll upload what I use. It looks like this:
Thanks for the reply. I couldn't find it. Unless I'm looking at the wrong section of NPM.
Is this part of SAM? If so, I don't have all my servers monitored in SAM. Mostly use SAM for critical servers running AD, Exchange, SQL.
90% of the servers we monitor are Cisco CallManagers and Unity.
The report is based off the HP proliant UnDP's found here: http://thwack.solarwinds.com/docs/DOC-89891
I've uploaded the report and you can find it here: http://thwack.solarwinds.com/docs/DOC-167482
Hope that helps!
Thanks. I tried that report which works and shows the exact one you posted above but on the UnDP file, I cant see the hardware model pollers (which you have on your report). Unless I'm doing something wrong.
I can see the HP components Array, CPU, Drive, Mem, NIC, PSU only under the Orion UDP.
Thanks again for your help.
My apologies -- I must've added some over the years I've uploaded all of the pollers you'll need for this report here: http://thwack.solarwinds.com/docs/DOC-167483
