anyone else seeing any trends worth noting? ive added @ 10-15 subnets this morning and noticed 4 gb missing from my hard drive, could this be related?
appears to be an unrelated problem
many thanks to all that helped!!!
i just got 2 gb back mysteriously
is this program writing huge temp files or logs?
Other than the SQL database, IPAM stores data in these locations:
The last two folders are where log files will go.
thanks for that info
C:\Documents and Settings\All Users\Application Data\Solarwinds\
is only 25mb, i guess that rules that out
orion, ncm, and ipam are the only things running on this server
im thinking it may have been tmp files that were written then deleted, i may have been mistaken on the original 4gb guesstimate since i had to get my sysadmins to free up some space yesterday which i think was caused by the same thing
just asked the sysadmin, he confirmed i am now missing 2gb and the only thing done to this server is adding 10-15 subnets in ipam
Do you have Orion NPM Beta running on this machine by any chance?
no, ive never installed a beta on this machine
