Are there any? What is new?
Here you go
https://support.solarwinds.com/Success_Center/Server_Application_Monitor_(SAM)/SAM_6-6_Release_Notes
Asking me to login?
I tried both my customer portal and my thwack user neither work.
Same here - Maybe stevenwhunt can help us out
What We're Working On Beyond SAM 6.5 (Updated December 4, 2017)
Application Dependency Mapping (ADM)
Leverage SAM’s ability to automatically discover the relationships between applications and servers, based on active application communication. Use ADM to discover and monitor connections between applications, as well as connections between applications and nodes. It can also show metrics such as latency and packet loss. You can use ADM data to:
Ensure that the most important data for specific applications are being monitored.
Identify unmonitored applications and processes that may need attention.
Leverage latency and packet loss metrics to identify whether an issue is caused by an application or the network.
ADM is available in several places within the Orion Web Console. The Incoming Connections resource lists all connections to and from the node or application and is available on the Node Details and Application Details pages. You may see the Connections resource on details pages even if the server does not have ADM enabled, because other ADM-enabled servers may be connecting to it. If you have Connection Quality polling enabled, you will also see latency and packet loss for each connection.
Other improvements
Monitor performance and availability of IBM AIX Power Systems with the Orion Agent.
Updated template names include Microsoft Windows Server 2016 if applicable.
Let me get with our Infodev guys and see whats going on. I also created a post in the Server & Applications Monitor Release Candidate section.
Everything should be fixed now.
