I see this randomly when starting the report writer on our server, and it is annoying. Maybe someone can compile the report writer with the licensed version of this Component One software, so we don't get these errors?
This issue has affected previous versions intermittently, but should be fixed in NPM 10.7. Workaround would be to execute the Report Writer in Windows 2k3 compatibility mode.
NPM installation is version 10.7.
That is really quite strange- we have not seen this on 10.7. Running report writer in 2003 compatibility mode should workaround, but a support case may be advised so we can understand why this occurred. Just curious- what features of Win32 Report Writer are you using that aren't available in the new web-reports?
In 10.7 can you embed web-based reports into pages like you can with report-writer-based reports?
Edit Page Layout -> Add resource -> "Report from Orion Report Writer"
In 10.6 it would only offer you the choice of Report-Writer reports and not web-based reports.
Not the finished reports, but custom table / custom chart resources from reporting are available in 10.7. The ability to embed finished reports is a known feature we need to port over.
