we want to monitor Alcatel OS6350 Switch paramters like power supply fan speed ,CPU & memory. Does NPM has it out of box ?
Hi
No NPM does not do that with Alcatel.
You need to make UNDP to OIDs that switch use for power supply fan ..
Universal Device Pollers (UNDP) - SolarWinds Training - Network Performance Monitor - Videos | SolarWinds
For CPU & RAM the "device Studio" will be better
Change device details in the Device Studio - SolarWinds Worldwide, LLC. Help and Support
thanks sja !! i am new to this OIDs. How can i get OID for power supply , cpu & memory for alcatel OS6350 ?
Don't have that kind of Alcatel in my shop
but mr google says that's
Seeking the SNMP OID's for... - Alcatel Unleashed
This will explain how Orion get the CPU from the devices .
Multiple CPU Count & Each Load on CPU for the Node
Please send me the FULL SNMPWALK as below and i will let you know the outcome where you can see all the OIDs supported within the device
Running SNMPWalk
Hi Sja,
Since the environment is restricted i cannot send u the snmp walk details
however, if i search in the walk result by power i got the OID but could not get for Memory & CPU.
i was able to get OID for Power Supply for the swtich
i also added it using UNDP. How can i show a view on Orion console showing the status of Power Supply for the alcatel nodes
Edit the UNDP on the server
Make sure it keep history and display in the web (in place you like node Summary I use Node Hardware TAB to that )
Make sure to test the UNDP on 1/2 node nice if you have a switch that has bad PSU
/sja
i was able to get OID for Memory & CPU. Does it also follow the same ?
Yes should be the same
But "Device Studio" is better for Memory & CPU because it use the native Solarwinds GUI
Device Studio is more through the web . In feature the UNDP will be gone from the Orion and only option is through Device Studio .
Manage pollers using Device Studio - SolarWinds Worldwide, LLC. Help and Support
I recall trying to do this for an Alcatel switch and not getting far because the SolarWinds GUI poller wanted Free Memory and Used Memory OID sources in bytes but I could only find Used Memory as a percentage. The GUI wouldn't let me create a poller with a memory percentage OID unless I am missing something? Ended up using UnDP instead.
i am looking for this to be displayed on Orion Console :-
You will need to use the Universal Device Poller (UnDP) tool on the SolarWinds server.
Monitor custom statistics based on OIDs with Universal Device Pollers
Create the 3 pollers and assign them to your Alcatel switches.
Is it possible to add it to the next release? It would be great to check hardware monitoring under list resources to monitor the hardware. Thanks
