Is there any way to change the default unmanage window from 24 hours to a shorter time period?
This is not currently possible today but is a feature request we are tracking internally under FB9249.
What exactly are you looking for when you say "default unmanage window". I am really not sure if something like this exist in Solarwinds. Probably it could be an unmanage window that is set in your environment (They could have used Unmanage Scheduling Utility to set this window you are talking about) , if you could give me more information probably I might have a solution for the same.
When you want to basically put a node in maintenance so you don't get alerts on it, you click on 'Unmanage' in the node details.
The you get the time window you want to apply...the default is 24hrs.
I want to know if you can change the default Unamanage Window to a custom value. Most of the time, we are just rebooting a server and don't want the rest of the team alerted unnecessarily.
Similar to the post mentioned below:
https://thwack.solarwinds.com/message/155946#155946
Cool
I guess its possible not really sure how, let me check if I can find something on this, thanks todd
Thank you gentlemen for the quick responses. I'll look for the option in a future release.
Todd
Hi, was this feature ever implemented?
Having the ability to customise the default Unmanage timeframe would be quite useful. eg. Mostly when we use the unmanage its for a reboot or other activity that lasts less than one hour.
Regards.
Not as of yet. What many users do is leverage the Orion SDK to add a shutdown and startup script which un-manages and re-manages the node when it's restarted via normal means.
Has this feature been put into production orion yet???
Bueller?
