Has anyone created a report similar to the NCM Community Strings for each node that will show servers SNMP community strings?
Looking to create a quarterly report to ensure that only specific community strings are used.
There should be a base report called "Community Strings for Each Node" which provides that exact information. It should be under Inventory.
Thanks for your reply, but this report only shows Cisco devices….Need have Windows servers as well.
With best regards,
Jeffrey Craig
Siemens Corporation
GS IT PS DO AGT
4400 N Alafaya Trail
Orlando, FL 32826, USA
Tel.: +1 740 914-1990
mailto:jeffrey.craig@siemens.com
Your organization is currently not activated for using SCMS (e-mail signatures). Please contact the IT Support or help.scf@siemens.com
Try this
Cannot execute the xml script.
When I try to execute it, it just displays the code.
Am I missing a tool?
Sorry, you need to import that file into your system from Manage Reports
