Hey all I need to filter out traps that contain a specific message I noticed the operator used when you select "is equal to" is like.
I just looked at the TrapRulesDetail table and theres a column for operator when you select "is equal to" the operator used is "like"
what do I need to do to get it to use "not like" basically I want the rules to ignore a trap that has this message in it.
