Failed to install updates (Error while running pre-install scripts) on Monday, February 6, 2017 3:21:01 PM GMT-05:00
That is all I get, any ideas?
And I got it figured out. I thought no way could it be the licenses, and it was, rookie mistake and I am no rookie. Dang man, and here I though I was smart.
I am experiencing the same exact issue. What exactly was the problem with the licenses, or what did you do to fix it?
Parker
Most license issues I see involve not having the primary license installed or if integration is enabled with Orion having both the primary and secondary license enabled.
