Attaching a screenshot.. Anyone know what is causing the error. Get error on page when selecting 1 node and selecting "list resources".
NPM 9.1 SP5
Brandon
Does this node have a lot of interfaces?
Is that what is going on? yes it has 64 interfaces 24 volumns and getting error on page. I have tried on a node with 4 interfaces 0 volumns and did not get the error. I also noticed that i get the error on page before it discovers "list" the interfaces.
Can't really say for sure, but it's possible. What resources do you have on your view for this node? Are there multiple resources which must show a long list of these interfaces?
You can also try following the steps in this thread:
Good luck!
I did find that post before but I could not find the LogAdjuster.exe file anywhere on the disk
To put the Web Console in the debug mode, open the \Program Files\Solarwinds\Orion\LogAdjuster.exe utility.
I have a 2 column view
1st column - event summary, search nodes, all nodes
2nd column - interfaces with high percent utilization, last 25 events
