Simplify and automate these patches and more with SolarWinds Patch Manager.
The Patch Manager catalog contains the following products:
Adobe
Apple
Mozilla
Change History (current month + 2):
03/10
03/04
03/02
02/16
02/11
01/11
12/23
12/17
12/14
12/10
12/09
12/08
12/03
12/01
11/25
11/23
11/13
11/12
11/10
11/09
11/03
11/01
10/27
10/22
Opera 72.0.3815.148
10/20
10/16
10/15
10/14
10/13
10/07
10/02
10/01
09/30
09/29
09/25
09/24
09/16
09/11
09/10
09/09
09/08
09/02
08/31
08/26
08/21
08/13
08/12
08/10
08/07
08/06
08/05
07/31
07/28
07/22
07/17
OpenJDK 8u262
07/16
07/15
07/14
07/09
07/08
07/07
07/03
07/02
07/01
Thank you much. I could see how people would confuse that and check all boxes but looking at it now thats a pretty good way to organize it and know what you are removing.
Thanks Sergio. We have updated the KB to make it clearer that you do not select the 'run below to uninstall options'.
Now I'm ticking the correct boxes it works fine! Thank you everyone for the help!
This is exactly what I needed. I tested this last night and Java 8.151 installed and version 8.144 was successfully removed! Thanx to all!
Ok, for Adobe Acrobat Reader DC, I see the updates for 2015 Classic. Will 2017 Classic be added to the catalog at any time in the future?
We are not currently using this tool, but I'm very glad that SolarWinds keeps updating it.
Hi! When you post the new Java versions, can you make sure to include
1. Java 8u161
2. Java 8u162
3. Java 9.04 (I think that is how it is named)
Thanks!
Jim
Java 8.161 upgrades were available as of yesterday, now just metadata. Can you publish these again?
Hi Wayne - there was a minor change required for 8u161 relating to the ability to uninstall previous versions of Java. You should see 8u161 packages available which were amended to allow the previous version uninstall functionality.
Thank you!!!
Happy Friday everyone! Question. With the new version of 7Zip, is there an option (Like Java) to uninstall the previous version of 7Zip? I tried using the Package Boot Manager but did not see the old version listed to remove.
Thank you!!
hdwrguy, i'll send you a direct message, but essentially: you have to specify the versions you want to remove yourself; it won't list them for you. (they do that for Java but not other apps)
Hello,
I would like to request:
1. Cisco Webex productivity Tools
2. Multi Commander (File Manager)
updates be added to patch Manager. Please let me know if this is possible. I have tried creating custom packages for these and have had some success but not reliably.
Thank You!
Sergio
You can request stuff added here
https://thwack.solarwinds.com/community/application-and-server_tht/patch-manager/patch-manger-feature-requests
Hi guys,
I was just wondering when you will be releasing Firefox 59.0.2 into PM?
Thanx!
Just uploaded to the catalog now.
Hello,maybe you are updating the catalogs?Because in the subscriptions only the apache product appears.Thanks in advanced.
Thank you. Can you also include Java 8u172 as well (and include the xx2 versions each time they are released)?
Apologies, 8u172 was uploaded to our catalog alongside 8u171. I've just updated the table above to reflect this.
Will the Adobe Acrobat DC Classic Track 2017 Catalog ever join the list for updates via PM?
Anyone else having issues with deploying Java 8 171? Version 8 161 had no issues, but when deploying this version it keeps coming up as not applicable.
I am trying to compare the two packages, but everything seems to be the same except for the version number.
Can you please confirm exactly which package you are trying to deploy? (e.g. x86, x64, etc)
Oh my, sorry. Yes, I am trying to deploy the x86 Upgrade and the x86 for x64 Upgrade.
Thanks - looking into the package logic now. Will report back shortly
Quick question. Has anyone deployed a Dell BIOS package to workstations that require a BIOS password? This process worked for a couple different models but is currently failing as the command line string is set to /s /r /p=PASSWORD. However, the next day I look and it failed. When I edit the package to check, the reboot and password switches are just gone.
We are working on adding support for the DC 2017 catalog, however you can add the catalog manually in the meantime. You can do this via Synchronization Settings-> Other Catalogs -> Add Catalog.
Link for the catalog:
http://armmf.adobe.com/manifest/arm-manifests/win/SCUP/AcrobatCatalog-2017.cab
Publisher: “Adobe Systems, Incorporated”
Name: “Adobe Acrobat DC Classic Track 2017 Catalog”
Description: “This catalog supports updates to the Adobe Acrobat DC Classic Track 2017.”
Awesome....adding it now! Thank you!
Well, I had selected 'Run Program' instead of 'Uninstall MSI'. Problem solved. Thanx for looking into this for me.
Ok, does this also include Acrobat Reader DC Classic Track 2017 as well?
And in my case I need to patch Adobe Acrobat 2017. We are running version 17.011.30080, but as far as I know, there is no patch in Patch Manager for Adobe Acrobat 2017.
