I am sure you are working on a SaaS Patch Management solution. I also know SolarWinds will buy companies. You should look at Action1.com and how that are attacking patching. 1st 100 endpoints are free, and they do a good job. I am thinking about using this with the SolarWinds Service Desk to have a rounded solution with Dameware SaaS offering. You should investigate it. You need to make movement in this space before you are left behind. You just talked about Secure by Design. Patching is part of your security offering. I just see a huge gap here.
