Good Day,
I have a question, but first i will state that I am new to SolarWinds. Here is the question, we just setup a new server running SolarWinds, and everything is looking good. When I attempt to grab Cisco running and startup configurations' I am getting that error, so I ran the test connection and it sucessfully connected to the switches in question. So i read online that you can change "config min length" from 11 to 1 lines. That then cleared the errors but when I check the running and start-up configuration on these cisco device they just show what I pasted below. Any ideas, I am guessing a device template ?
Cisco 4507, 3560x, 3850, 3560cx are some of the models that are having this issue
| Config Type | Running |
| Downloaded | 3/28/2023 12:30:05 PM |
| Modified | never modified |
| Comments | |
| 1: | ^ | | 2: | % Invalid input detected at '^' marker. |
