Hello,
We have some database monitored with AppInsight for SQL and some of them are in unknown status with a message like
Unable to establish SQL connection, check credentials. Login failed for user 'xxxxx'.
i'm looking to create a report on all the database with this kind of message.
Do you know where i can find this message using SWQL or SQL ?
This will be very useful to help troubleshoot the SQL monitoring.
Cheers
