We are looking for APIs to get the events and performance data from SolarWinds and integrate that into our Data Warehouse for reporting purpose. Is that possible using Orion SDKs?
Have a look at this thread:
Orion SDK Information
Contains info on the SDK itself, and links to download it
These links will help you with the API / SWIS:
http://www.cheatography.com/ernest/cheat-sheets/solarwinds-swis-api/
How to Use the SolarWinds API and SDK
Hope that helps! If you're looking for a specific answer, or don't have time to use the links above to puzzle it out, raise a support ticket through the customer portal
