Hello,
After getting nowhere with support who are refusing to assist with this I was hoping some other users of NPM may be able to assist since "SQL Querys are outside of support scope", even though I dont agree the SQL is at fault.
Basically I am trying to alert for certain IP Addresses where 4 of my 5 custom properties are blank. The Custom Properties being - DEVUATLIVE, KeySystem, Region and Segment)
SELECT Nodes.NodeID AS NetObjectID, Nodes.Caption AS Name
FROM Nodes
WHERE (IP_Address LIKE '%10.120.4.%' OR IP_Address LIKE '%10.218.0.%' OR IP_Address LIKE '%10.218.1.%' OR IP_Address LIKE '%10.218.2.%' OR IP_Address LIKE '%10.218.3.%' OR IP_Address LIKE '%10.218.4.%' OR IP_Address LIKE '%10.218.5.%' OR IP_Address LIKE '%10.218.6.%' OR IP_Address LIKE '%10.218.7.%' OR IP_Address LIKE '%10.218.8.%' OR IP_Address LIKE '%10.218.9.%' OR IP_Address LIKE '%10.218.10.%' OR IP_Address LIKE '%10.218.11.%' OR IP_Address LIKE '%10.218.12.%' OR IP_Address LIKE '%10.218.13.%')
AND (DEVUATLIVE IS NULL OR KeySystem IS NULL OR Region IS NULL OR Segment IS NULL)
Checks every 12hrs and alerts only if condition exists for more than 1hr.
The problem is that when the alert does detect nodes it triggers and I get notified about the missing values. I then set the values and wait for the reset to occur, this doesnt happen; I have to go in manually and clear the alert from Advanced Alert Manager.
I have executed the SQL via MS SQL Management Studio and Solarwinds DB Manager (once the values have been added after the alert was triggered) and it returns 0 rows
If anyone can test a similar query or point out what is wrong please can you do so.
Peter
