Description
This procedure will return the top index advice for the number of days back specified. It ranks the list by the amount of wait time saved. See comments inside the procedure for more details on the parameters and methods for calling. Install the stored procedure into the Ignite repository database.
Stored Procedure
IF (SELECT COUNT(*) FROM SYS.OBJECTS WHERE NAME LIKE 'TopPlanAdvice') = 1
DROP PROC TopPlanAdvice
GO
-- TopPlanAdvice PROC
-- PARMS @Instance, @DaysBack
-- EXAMPLE:
-- EXEC TopPlanAdvice 'DBA-001\OPSMGR', 14
CREATE PROC TopPlanAdvice
(@INSTANCE VARCHAR(50), @DaysBack VARCHAR(7))
AS
DECLARE @SQL VARCHAR(4000), @DBID VARCHAR(3);
BEGIN
SELECT @DBID = ID FROM COND WHERE NAME = @INSTANCE;
SET @SQL = 'select TOP 20 * from ( '+
' select sqlhash, sql_text, advice, impact, sum(timesecs) timesecs, (impact/100)*sum(timesecs) seconds_saved '+
' from ( '+
' select ps.sqlhash, '+
' substring(st.st,1,200) sql_text, '+
' substring(a.advice, charindex(''):'',a.advice)+3,1000) advice, '+
' convert(float,substring(a.advice, charindex(''(Impact'',a.advice)+8,4)) impact, '+
' ps.timesecs '+
' from con_plan_sum_'+@DBID+'; ps '+
' inner join conspa_'+@DBID+'; a on a.plan_hash_value = ps.planhash '+
' inner join const_'+@DBID+'; st on st.h = ps.sqlhash and st.p = 0 '+
' where ps.datehour >= CURRENT_TIMESTAMP - CONVERT(float,'+@DaysBack+'
) i '+
' group by sqlhash, sql_text, advice, impact) impact '+
'order by seconds_saved desc';
EXEC (@SQL);
END;
GO
