Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Monitoring inbound vs. outbound calls on DS1 PRI - AS5400
BxR
I’ve searched high & low for this ability using several software packages & I can't seem to find the answer.
Simply put, we need to chart/monitor/alert on the number of inbound calls on a particular DS1 on a AS5400.
Just charting the data is the first priority which hasn't happened. This AS5400 has 8 total PRIs, so getting this info specific to a single PRI is imperative. Version 8.1 Orion allows you to poll the
chassis
of the AS5400, but when I specify T1 7/6 for example, the custom poller doesn't work & shows "failed".
What am I polling?
Using the
CISCO-POP-MGMT-MIB
I'm trying to report on
OID 1.3.6.1.4.1.9.9.27.1.1.3.1.3
Description:
"The calling number for this call. If the number is not available , then it will have a length of zero. The variable is instantiated if this is an incoming call."
On the flip-side, we should be able to report on outgoing calls using
OID 1.3.6.1.4.1.9.9.27.1.1.3.1.4.
Questions:
1. Is this the correct MIB?
2. Is this even possible using a custom MIB poller? (it is
here
3. Should I try the CISCO-ISDN-MIB, CISCO-ISDNU-IF-MIB or CISCO-VOICE-IF-MIB? (some I've tried to no avail)
4. Has anyone come close to getting this data using Orion?
We have What's Up, PRTG & Orion & I can't seem to get this data. With the thousands we've spent on Solarwinds it should be very easy, no?
Any help or hints to variations of this request will be appreciated.
Thanks!
Find more posts tagged with
pri
SNMP
custom_oid
custom_poller
voip
isdn
calls
custom_mib_poller
inbound
as5400
as5350
custom_mib
outbound
Accepted answers
All comments
There are no accepted answers yet
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
