Hi.. i just wanted to know if there is any specific CSR that needs to be generated for Orion Web Console SSL? If yes how do i generate it.
You can use it temporarily to enable SSL but it will show up as "Not Secure" when going to the website
In 121 this feature will be built in.
Native SSL support for the Orion Web Console
Seamlessly bind SSL certificates to the Orion Web Console and enable HTTPS connections using the Configuration Wizard. The Configuration Wizard scans the Orion server for valid SSL certificates that you can choose for the binding, or you can generate a self-signed certificate on the fly.
I don't think there is anything special about CSR requirements. Treat it like any basic SSL'd IIS site.
You can use the built in Orion CSR if you don't have your own.
Enable SSL or https for the Orion Web Console - SolarWinds Worldwide, LLC. Help and Support
I read it somewhere before that it is not recommended to use built in Solarwinds SSL Certificate. That is the reason i was trying to get the SSL certificate for the windows server.
