I'm getting this trying to manage nodes after my upgrade to 9.5. Anyone else having this issue. Happens from work station and on server also.
I have not heard that from anyone else. Have you opened a Support ticket?
I just submited a support ticket. I'm also getting the error on the server:
Database configuration failed: • Incorrect syntax near 'EXTERNAL'. You may need to set the compatibility level of the current database to a higher value to enable this feature.See help for the stored procedure sp_dbcmptlevel.
Thinking very seriously about rolling back to v9.0 sp5......
Ah, that helps a ton, see KB here
the compatability level window is grayed out. says SQL Server 2000 (80)
do you think the issues are related or 2 different issues?
Seems like they may be related, do you have a support case open?
I do...
Your request for assistance has been received. Case #99284 - "Getting Internet Explorer Error" has been created for you. A member of our customer support team will respond to your case as soon as possible.
Thanks for the help thus far..
