we know Orion alert can generate sound alert in system manager.
and if my Orion server located in the remote location, then I want to listen the sound alert in another monitor office.
how should I do?
Thanks.
you might have to run a command on the remote machine.
Big thing is to make sure the sound file exists on the remote machine in a known location.
It's interesting. This is almost exactly the same question (same wording and everything) that was posted back in 2008: https://thwack.solarwinds.com/message/47713#47713
Check out the thread there for several options.
Hello,
Leon is right.
Summary:
The best workaround is use any email client with filter which have play sound as action.
4. Use "Play sound" as action.
Another workaround:
Yes, it is same thing, Actually i wanted know the answer for this question that is reason i updated again for getting some new answers for this.
